Four50
After reading every post I can find on this subject I want to make sure I'm right and have a question.
Ok so all that I can determine is that the carrier has changed. In so that the bolt pattern is different for the ring gear correct? So that's keeping aftermarket gears from fitting. Same for the aftermarket lockers/posi units have the old carrier bolt patten so they say they won't fit the new oem ring gear bolt pattern?
So, I have to ask the question. Why not just install an aftermarket posi with aftermarket gears that was for the 2010 down rearend?
