2012 Factory Door Speaker Perfect Replacement (6x9)
Caldwell
Philadelphia
as long as the top mount depth of the speaker is 3'' or less, you will have no problems with install ^^^^^
Larsin
2013 Bighorn Crew Cab
Caldwell thanks!
Looks like the Alpine SPR 6x9s are JUST in:
Top Mount depth: 2-7/8"
BIGBLACKHEMI
Jersey
I had them in a beater and they were great.. good to know they fit in the ram
PX8
2013 Express Crew Cab
They are tight on the 13 in the back believe it or not. The connectors will have to be bent all the way flush in both the front and back. I'm unsure about the quick connectors that Crutchfield has though. Very loud treble and mid with 60watts true RMS going to them. I believe I'd like to put some spacers on them anyway and try some baffles behind them just to experiment with the bass response. I have played with them quite a bit with my sub-channel turned off and it's pretty dang awesome without the subs. I have the MTX thunderform with the supplied 10's and wow the combo is nice. I also put JL 3.5 in the dash running off of the HU. Honestly, they are absolutely awesome, if powered by an amp they really would give those 6X9's a run for their money in the treble mid department. I honestly am lost for words on how crisp and clean my system sounds. Not the loudest system, but at 550watts rms it's plenty for me. My ears will hurt for a while after a ton of AC/DC.
Larsin
Got all my speakers in, and started the install last night only to find I did NOT have a 5mm socket lol. Ran to Lowes and then discovered I didn't have the wiring connectors....so I ordered those from Crutchfield for the 6x9's.
Glad to hear they fit(albeit with a caveat), and can't wait to get them hooked up.
PCT
2019 2500 6.4
Northern California
Sorry to resurect an old post. i just bought the kickers OP got for a gift, the rear fit fine and they sound great... will they fit with a spacer plate? I ordered a 3/4 inch spacer plate?
MoreOvalteenPlz
MoreOvalteenPlz
Stillwater, OK
It should work. I know guys on here have done it. It's just a tight fit once the door panel is back on.
mvm2
