2012 Outdoorsman 1500 6" RCX and Air Bags (installed)
Thor09
Northern PA
Hey guys, it was a long day but we got the 6" RCX put in my 2012 Outdoorsman yesterday. I already had Bilstein 5100s maxed out and I put in a 3/4" Top Gun Customz rear coil spacer. I also put in Air Lift 1000 air bags. We had a few snags and had to run to a dealership in the middle of the installation (whoops) but we got it done lol
I should have listened to Jake09 but the 3/4" rear coil spacers are too small, I am going to need to install 1.5" rear spacers. I know my front end will drop slightly when I get it aligned but here are the results:
Before Lift with 35s: Front were both 39.25", Rear were both 40.25".
After Lift with 35s: Front Drivers 45.25", Front Pass 45.5", Rear both 45"
I'm slightly nose end high and even if the alignment brings the front down 0.25"-0.5", I didn't want it pefectly level so swapping to the 1.5" rear spacers should fix that.
The Air Bags were easy. They required no support under them inside the coils because once you slide them in and fill a few pounds, they don't move. I have not hauled anything yet but will get back to you with their performance. I'm running 15 psi right now and it rides pretty darn good other than the alignment being out.
The one thing we had to do since my Outdoorsman has the single exhaust was removed the rear tailpipe and resonator to drill the holes for the tract bar drop bracket. This is not mentioned in the instructions.
This is my 2nd 6" lift kit install and I actually like the RCX over BDS. I put a BDS in my 2009. The RCX retains the factory front brake lines and tie rod ends. With my 09, I blew a BDS brakeline and my truck sat for 3 days waiting for a part. With retaining the factory lines, I can run to the dealership and repair the same day. That's just my personal preference I guess in being able to repair something...if needed.
I have a ton of pics so here's the start of some...
1) Before Lift
2) Front Diff out
3) Front completely stripped
4-5) Lifted!
Thor09
Thor09
Northern PA
Here are the Air Bag pics. I ran the small tubing from each bag to a tee. It says keep tubing 8" away from exhaust. Then from the tee, I ran the tub to the rear and mounted the valve stem next to my hitch. It works basically like a tire.
Thor09
Thor09
Northern PA
I gotta say the hardest part of the installation was getting the steering knuckles back into the lower ball joint/lower control arm and then worst of all the upper ball joint/upper control arm. It is very tight with the Bilsteins maxed out. It took 3 of us over half an hour to get them back in correctly and tightened up.
GlOcKnRaM
Mebane, NC
5.7L V8 Hemi
Looking good man! Love the lifted Outdoorsmans!
Thor09
Thor09
Northern PA
Thanks Kevin! I'm glad its done and was driveable lol
Here's a few more pics....
Thor09
Thor09
Northern PA
Wow, that is very nice. I bet you're happy!
Thank you! I'm very happy! The 35s look small for now but I'm going to run them through winter. I have my old super polished chrome 20s and 37s sitting in the garage but I'm not sure how the chrome is going to look. If I can sell my old 20s, I'll get different rims. If I can't then maybe I'll just plastidip them, I guess I have all winter to think about it lol
jake09
Looks sick brad!..truck is a beast now!
fastNugly
Toronto, ON
2012 Dodge Ram Sport CC
Damn man!
Looks flippin good :drool:
Pls tell me how the airlift works out for you as I want the same thing.
35's don't look too bad on a 8-9" lift too
Bigdaddy
2022 3500 Laramie CCLB
6.7L Diesel Cummins
Man, that look wicked.
1500ram12
5.9L Cummins
Love your truck can't wait to see what wheel and Tire combo you are going to run
Sent from DROID RAZR MAXX using Tapatalk
fastNugly
Toronto, ON
One question though? I have my air lift 1000s installed, but I have a 2 inch rear drop xD Is it for offroading so the truck doesn't compress that much? Because it doesn't look like the back is doing much at all just sitting in there and not resting on the actual axle lol
Thats the thing....most people think it needs to be resting on something to be effective, however that is not the case.
I have called into airlift twice and spoken to their techs (2 different ones) as did Thor09 and we got the same feedback.
basically how they say it works is that it inflates outwards to press against the spring not allowing it to compress as much.
The more it is inflated, the more the spring cannot compress.
so, it does not have to rest on anything as it doesn't inflate vertical, rather it inflates outwards
As you know, I am lifted as well and this is something I want to add to mine and had to be certain how it worked.
Johnnguyen6596
