2012 ram 2500 5.7 Hemi What Diff oil/Transfer Case Oil.
jws123
nj
2012 ram 2500 5.7 Hemi 218k What diff oil/Transfer Case Oil does this truck use? and what brand oil do you guys recommend?. This is my fathers truck got it 2 years ago with a blown motor rebuilt it been great so far however getting some driveline 'noises' figured il start with flushing everything since it has never been done by me truck was also abused a bit looks to be a former plow truck.
kurek
Northwest
If you get on mopar.com you can create an account with your VIN and have access to an online owners manual and maintenance guide, any recalls that apply to your truck and any dealer service records from it if applicable.
jws123
jws123
nj
Did not know that will check it out thanks.
For fyi, your coolant is 5 year Chrysler HOAT. Your owner manual here.
Front and Rear Axle – 2500/3500 Models
Synthetic, GL-5 SAE, 75W-90 or equivalent. Limited-Slip 10.5/11.5 inch Rear Axles Limited slip additive is not required.
Transfer Case MOPAR ATF+4 Automatic Transmission Fluid or equivalent licensed ATF+4 product.
Transfer Case – BW44–44 Only MOPAR BW44–44 Transfer Case Fluid or equivalent.
I like redline c+ for your transfer case, that is what I use in mine as well, even for the 44 we have guys try those unicorn tears 44 fluid and amsoil and redlne, just go redline c+, less then 3 quarts. @Hemi395 used all options in his 2012.
For gear fluid I like amsoil sg in the bags, or you can use redline 75w90 you do NOT want NS in the title, that is for older gear boxes not for 2012 gear boxes. Less then 3 quarts per diff for 1500, not sure if it is the same for 2500 diff.
Jeepwalker
WI
2012 Reg Cab, 4x4
I use Walmart Synthetic gear lube in my truck's diffs. It's inexpensive and I've never had any issues with it. I've probably used it for close to 15 years, maybe 20 in various vehicles that I've driven tons of miles.
I use the proper Mopar fluids in the transmission, xfer case and power steering (from Chrysler). Amazon sells them. By now some of the numbers may be superseded, I'm not sure. But non-Mopar +4 would probably work fine. It has to meet the specs.
DILLIGAF
Canadian Forces
Canada
Amsoil website will show you everything you need.
Arturo Rojas
