2012 Ram 5.7 Diablo Tuner
ramwad
Labelle
Got a quick question on this tuner. I got a diablo trinity 2 platinum tuner and need some advice on the on board tunes. Until I can get some cash saved up for a Greene tune, which tune would be best for my application? Mild stuff is installed, Vararam Intake, AR Longtubs and a Borla Pro XS (muffler only) stock pipe from headers back. The fella that installed my headers made some custom adjustments and I have been ok with it but just wanted to know if there is a good all around tune stored for now that will also be good. Its very hard to get 91 where I am at and I don't mind running 93 but, I am not sure if I could try the 91 tune and run 93, run Diablo Tune and run 93 or the CAI Tune. Any help would be greatly appreciated. More questions is ok too if that help, not sure what else to put.
Uncle G
virginia
I also have the vararam intake with arh long tube headers with the y-pipe/cats,14” muffler , pedal commander,87 mm throttle body. and a Diablo trinity tuner as well. The oil dipstick required a “custom bend” so it could clear the headers. On the passenger side above the downstream o2 sensor the heat shield needed to be beat in(tweaked) with a hammer to get it to fit. Only broke 3 bolts off in the heads when removing the old stock headers.
I have been playing around with the different tunes preloaded from Diablo. So far I’ve used the 93 /91octane tune and the Diablo tune with 93 in the tank with no issues. Driving conservatively I can knock out 20+ mpg. 2012 1500 bighorn 6 speed 100,000 miles.
MADDOG
Living in a Firepit
6.4L HEMI
You can run the 91 tune with 93 octane. What you DON'T want to do is run a 91 tune with 89 or 87 octane fuel.
DILLIGAF
Canadian Forces
Canada
Get a custom tune
