dss56
I have a 2013 Ram Big Horn Hemi.
I have noticed a small rumble in the front of the engine while running.
I checked the Idler pulley and fine.
I have a regular clutch fan and it has a small warble to it.
I grabbed the fan blades and it will warble about 1/8 inch on the shaft closest to the radiator.
I also put a wrench on the nut to wiggle the shaft to see if its the water pump shaft and its as tight as can be.
Would this warble on the clutch fan be normal and would it cause the small rumble when im in front of grill I can hear the noise?
If you all think its on its way out would a good aftermarket part work, as an OEM is $250.00, the After market fan is a bout $70.00 shipped
thanks
thanks
