2013 Ram 1500 4.7 Heating issue
mesta80
NC
I’ve got a 2013 ram 1500 4.7 that had water pump go out on it. Changed the water pump, thermostat and fan clutch since i was in there. It still wants to over heat no matter how many times i bleed the system. Little back story…..before i think the thermostat was stuck open it stayed at 203 and the heat was barely getting hot. But now it keeps overheating after bleeding the system and heat is now hot any ideas???
pgoodwin79
Quinton,AL
Might be a stupid question but you didnt accidentally put the thermostat im backwards did you?.....if thermostat is in correctly.....i would ask do the hoses get very hard when it starts overheating?
