2013 ram 1500 2wd spindles
hunter2013
Will the ebay chassis tech spindle work on a 2013 ram 1500 2wd?? I also have a 2.5" daystar spacer id like to keep on.
RamRod
Western NY
2013 Black Ram express
i have heard a few guys doing it and not had a problem, just swap the brake lines from side to side. How did you get the 2.5" spacer in your 2wd? i tried it was just way to tight, i had two spring compressors and a rachet strap and i still couldnt get it to seat in the bottom cradle.
H
hunter2013
I used a coil compressor also and i was told it wouldnt go in also. I put it in in about and hour and a half 2 hrs. I put lifts on for a side job and this level was by far the toughest level ever. You have to compress one side of the spring and make it curve inward and set spacer on top and push lower control arm down and set it in and jack it up lol.
H
hunter2013
Its actually a 3" spacer off ebay. It measures 2.5" thick total. But to where the spring sits it measures and 1.5 and due to the ratio thats a 3" level. Rides a little stiff tho but i love the look sits 39" in back and 39.25 in the front.
