George Salov
- Apr 29, 2020
- 3
- 0
- Location
- Kimberling City, MO USA
- 2013
- 3.6
As the title states, plus it has a 3.21 rear end.
Problem is the dealer stated the tow rating was 7100 which is higher than I needed. So I bought it. First time pulling boat which weighs in between 4500-5100 I got a engine light and it went into limp mode.
The code was PO365 which is cam shaft position sensor. Replaced it the next day. The following day, pulling boat same roads, check engine light came on and it went into limp mode again. This time the code was PO369 still the cam shaft position sensor but it shows as a intermittent problem. Cleared code and truck runs fine.
Since this I have tried to get accurate information on the tow ratings. I have found 3 different ratings. One says 4100#, another claims 7100# and even found one that claims 9100#. If indeed it is 4100# and my boat exceeds that weight would or could that be causing the check engine light and the error codes?
Why would Ram or anyone make a full size truck with such a low weight tow rating. I should mention that this is a regular cab short box truck. We really love the truck, but the reason we purchased was to pull boat. Need some advise and help on true tow rating.
