2013 Ram 1500 tradesman grille swap (top mount)
Berto211
Manteca CA
Hi All,
I recently purchased my first ever ram.
I am trying to make the front end look a bit better so I purchased an
oem Laramie style grille, it fits perfect however it did not come with
the top mounting bracket/support, and the one from the original grille does not fit,
any ideas on a part number or a link to where I can purchase?
1st picture is one I found online with the part that I need, the other 3 pictures are of the grille I actually purchased.
Thank You.
tron67j
Maryland
Maybe Benny at All Mopar Parts in vendor section can help.
What year was the grille that you bought ?
Your Ram Tradesman is a Ram Classic DS Edition, Classic means that it is a 4th Generation Ram
If your new grille is from a 2018 Laramie Longhorn & looks like this, i do not know that it will bolt up ??
This might be called a Ram DT 5th Generation New Body Style
Maybe you could look at a Ram 1500 Rebel grille
You would have to do some measuring, etc.
Maybe some one on here would have more knowledge
