2013 Ram headlight issues....
Bigtruckfanatic
First ill start with sorry if there is a thred pertaining to this already, i wasn't sure where to look for this. I have a 2013 Ram 1500 that has some wiring issues and upon doing some research it seems that Ram headlight issues are fairly common. So I have already checked bulbs and they are all good and it seems to be a connection issue. Where can i buy a new harness or if someone has had this issue, i was wondering what they did to fix it. Any information would be most helpful, thank you in advance for all input.
Wahrsuul
Central S.C.
Mine's an 09, so not sure what differences there are, but my fix was simple - I removed the headlights, and gently twisted the flat pins inside the headlight connectors. Filled with dielectric grease, re-installed and haven't had an issue since.
B
Bigtruckfanatic
My truck is prior salvage and the problematic side is the side that was previously smashed before. The connectors themselves i believe need to be changed as the clips are broken and wont funtcion unless held in place. I'll tinker with it some more and try the grease otherwise ill need to find some new connectors.
Crapo85
