2014 1500 Climate Control Won't Turn On
Robert Ram
Lebanon, Mo.
Bigshaff44 My 2016 has the same problem. What is the control module called?
Robert Ram
Lebanon, Mo.
bigshaff44, I have a 2016 ram 1500 with the same problem. What is the name of the control module called?
Mandalea2002
Andalusia Al
I am having this same issue, as your video, was the the knobs thing you had to replace? Sorry I am confused if it was the heater module or climate control. Trying to fix mine myself and need to order the part.
Javigo1971
Phoenix Az
Hi guys... Somebody knows where. Can I get a wire pinout diagram for the 2018 hvac control module...? Cause I having issues with the ac not blowing cold
.. Only if I connect the original manual bezel back will cool again.. Everything else will work fine so I assuming the harness is missing a wire position for the ac compressor to work.. Maybe?
So far I found that the number 10 wire on the truck harness side has only 5volts instead of 11.6 volts that the original bezel has... So something is wrong here.. Thanks
I have a 2014 ram 1500
8. 4 radio Vp4 swap for a 2015 truck
2018 brand new havc module..
Any help will be appreciated it.
Jrouille
BTV - Burlington Intl in Burlington, VT
I am dealing with the same issue. Turned truck on today and have zero control over my climate control. Won't turn on with soft or hard keys. Brought to a mechanic and he said it's most likely the uconnect system. 1500$ new or $500 rebuilt. I'm hoping someone has a cheaper definitive solution. I wanna try the climate control module. Though I have no idea if that's the problem. There were no other issues what do ever with anything.
rsdata
N Ky
2014 BigHorn 1500 8spd 4X4
For two years now... I have lost my rear camera and it sometimes takes 2-3 minutes for the screen to boot and be able to have control over the HVAC unit... although the controls eventually start reacting. I have found if I leave AC on when I shut down, the AC is running when I start the next time even if I cannot control it right away.
What a stupid system...
I had my 8.4 unit worked on once when the GPS went out by Infotainment dot com about 3 years ago. It broke again a little out of their warranty period, but the radio and HVAC WILL work after 2-3 minutes of blank screen. SOmetimes it works right off the bat...
I ADDED an aftermarket backup camera... but I wish I could fix the OEM unit.
