2014 1500 Component Fit,amps, etc.
dollar12
(questions are for someone elses truck, Im just trying to help)
He has a set of Image Dynamics CTX6.5cs components. Here are the specs
6-1/2" CTX Series 2-Way Car Component Speaker System
Power Handling:
Peak: 400 watts per set / 200 watts each side
RMS: 200 watts per set / 100 watts each side
Recommended Power Range: 25-200 watts per side
Mica-Polymer cone
Butyl rubber surround
Silk dome tweeter
High-energy neodymium tweeter magnets
4 ohms impedance
High temperature and high power voice coil
Sensitivity: 89 dB
Frequency Response: 55-25,000 Hz
Top-mount depth: 2-3/4"
(bottom mount is 2-7/8")
I know they aren't shallow, but does anyone know if they will fit (assuming the installer will use spacers, brackets, etc).
Also, has anyone have experience with netaudiowf's sub enclosures? Are they worth the price, or would the fox acoustics be fine (considering maybe 500-1000 watts of power to the subs, and possibly 2 10"s).
Also, where would a good area be to place the amps (possibly 2 amps, unless a good 4/5 ch would work/fit)? It looks as if both front passenger seats have the air flow underneath.
thank you
Informal
SoCal
2015 Sport 4x4
I would search 2012-2013 Rams on Crutchfield.com They have quite a bit of info there regarding mounting depth etc..
Etroze86
Grand Forks ND
It will be tight for sure on the mounting depth I know mine was a hair under 3" and with the adapter plate it just fit. Amps will fit fine under the seats as long as you aren't putting and odd double stacked amp under there which there are few and far between on those so you should be alright. Don't have net audio box but I do have a fox box for my reg cab and it works fine for now. I am going to make my own for sure in the near future.
BlkRamRt
SoCal
HEMI 5.7
they will fit if they make the adaptors out of wood.
cdub5
