2014 5.7 Hemi PCM
Gunny97
South Carolina
Just found out my PCM is going bad, Can it be reset or do I replace it. I also want to know if getting a replacement like Diablo would increase performance. Any suggestions welcomed
Semper Fi
The 14's don't need an unlocked PCM to be tuned,so a dealer replacement PCM is all you need.The 15+ trucks require an unlocked PCM to be tuned,so there's no gain for 14 by buying a pcm from Diablo.You need a tuner though to tune your 14.By having a 14 you save a bunch money,as your stock pcm is tune-able by either Diablo or HP.If you want tranny tuning,you'll have to step up to the more expensive HP tuning platform,as Diablo doesn't support the tranny in a 14
MADDOG
Living in a Firepit
6.4L HEMI
Sounds like you need a reman or new PCM.when you purchase a new or reman PCM it has to be flashed, at the dealer, with your truck's info and VIN so that it will operate properly.
The Diablosport tool is a tuner that is a separate component you use to upload a tune to the PCM.
G
Gunny97
South Carolina
so i am stuck buying from the dealer and paying them to flash it instead of me just putting it in correct?
G
Gunny97
South Carolina
that don't have mine in stock but will have in a week, thanks, the dealer isn't getting a grand on this guy awesome
Jwithing
STL
Are you out of warranty?
G
Gunny97
South Carolina
yes, I bought a 100,000 mile and the truck had 5000 on it. when i went in i was just over 100,000. they said sorry your not covered even though i was told i was
G
Gunny97
South Carolina
Gary,
I finally got the PCM from the company link you sent me and put it in the truck, Prior to me getting the PCM I started and finally lost power and my truck went into creep mode doing maybe 5 miles an hour and the dash indicated I needed to service the electronic throttle control. I was hoping this was all due to the PCM but I was wrong. I put in the PCM and fired her up great for maybe 10 seconds and she died. now she just cranks no fire so i guess I need to replace the electronic throttle control now
Thanks for your lead on the PCM and any advice on this issue.
G
Gunny97
South Carolina
PCM was bad and sent it back. They are sending another one. I also had the lightning bolt come up showing the ETC needed to be worked on. Do you think I should just replace the ETC to avoid further delays getting back on the road? I called the dealer and they gave me hell for not bringing it in so they could charge me an arm and a leg to do what I have done for less than 400 bucks. They told me the existing ETC has to be reprogrammed to forget not working.
FCA Master
West Texas
The PCM needs to learn the ETC parameters to function properly. A good aftermarket scan tool should be capable of doing this.
G
Gunny97
South Carolina
ok thanks, when i get the PCM before i run the motor i will scan first and close out any codes. I have had the battery off so i dont expect any
theWillis2014
Alabama
Which model HP? I am pretty confused. Need tranny tuning on 2014 8 speed. Thanks.
