2014 Crew Cab Front Door Speakers
Solej
OK, here is my question, has anyone found a 6 x 9 speaker that will drop in the front doors with no major modifying? And of course sound good, or are we stuck with the 6 1/2"???
Sent from my 0PJA2 using Tapatalk
jbr
Long Island, NY
My stock 2013 had 6x9 and I swapped them out for 6.5 kicker (low end model). It made a difference even with the 5.0 head unit.. They did take awhile to break in.
Etroze86
Grand Forks ND
You can put almost anything in the doors and make them sound good. It just takes time and money. I prefer 6.5s because it is so much easier to find a decent mounting depth.
MoreOvalteenPlz
Stillwater, OK
The search function is your friend as this topic has been covered on here many times... Regardless, Kicker makes a 6x9 drop-in upgrade through Mopar. I run Alpine SPR69's which are drop-in as well and have a higher RMS rating (200W per pair) than the Mopar Kickers. MDF spacers can be made/purchased to install deeper 6x9's. Anything over 3" depth will need a spacer. A lot of guys prefer to run 6.5"'s with adapter brackets. I run Kicker DS69's (3 3/8" mounting depth) in the rear doors with no fitment problems as the rear is much deeper.
noupf
NY
2015 CC Sport 6'4 Bed
you might want to clarify if you have the alpine or non alpine sysstem. That fact makes a huge difference on the proper answer
reek
Sacramento
2015 RAM 2500 CC 4x4, 72 D100, 73 D100, 01 RAM 2500 field truck
jbl gx962s have top mounting depth of less than 3 inches
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
The Kicker Mopar 6x9s are a direct plug and play, same plug as factory, and will really enhance the sound. You wont see any gains on a speaker that handles more power, unless you give it more power.
Stock power is stock power.
Solej
Solej
Non alpine system
Solej
Solej
I put in the Kicker plug and play, super easy install. Did all six speakers in about an hr.
Where did you find the Kicker mopar speakers?
jeffdawgfan
Don't know about the non-Alpine system, but on the Alpine you only get a mid-bass output to the front doors. Putting any type of full range speaker is a waste. Look for a pair of 2ohm mid bass speakers...if it's like the Alpine and you do not get full range to speakers.
Graygoose
Oklahoma
Convert, for now.
small
Vendor, Allmoparparts, Benny can get them
