2014 Express Center Console Swap question - I HAVE SEARHED
DARKNHT
Georgetown, IL
Hey guys...
I just picked up a 14' Express Crew Cab and want to do the Center Console Swap, and shifter swap. I have the list of needed parts but I just want one clarification..
09-15 center consoles will work regardless I just need the 2014 dash bezel for the console correct? (outside of the USB hook up not being in them prior to 2014)
coolemoff1
I may have the dash bezel u need Wednesday have shipment of items coming had to include bezel to get the rest I don't need it
Send email or pm if interested
coolemoff1
Console
I just finished mine I have in console cd I'd get rid of as well
mattydipps
i modded my new dash bezel to work with the usb port when i did my center console install, so it is possible to keep the usb plug working.. i could be wrong but i believe anything from 13 and up will work with a 14...
best thing i did, and the easiest, was just making sure that the new bezel looks like the one your trying to replace.. all of the mounting hardware will be the same.
nyciti
Console is easy....be careful with the shifter swap, its not the same tranny in a 14 and the linkage I believe is different so it won't work. If you have the knob to put the truck in gear you can't do the shifter swap. (at least i have not seen a single on done) BTW I did the shifter swap on my 13 6 speed.
