2014 Ram 1500 Express Towing...
mrodaz
Ok I'm new to this so please bare with me. I am loooking to tow a toy hauler with a bone stock 2014 Ram 1500 Express. Trailer weighs 6500 lbs dry, once loaded with my RZR that would put us around 8300 lbs not including anything else in the trailer. I am wondering how much weight I can safely haul with passengers and cargo.
please please help...
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
I think you'll be over your payload limit with that rig.
What is your payload limit on your yellow door jamb sticker?
From that figure subtract the weight of all passengers and cargo in the truck, the weight of the weight distribution hitch (you'll need one ) and the tongue weight of the trailer, which on that rig is likely in the 1000 lb range or so, perhaps a little less since its a TH.
You probably have a payload in the 1500 lb range or so, so that's only 500lb left for weight of all passengers, cargo and the wdh. Probably a no go unfortunately.
Half tons have artifically high tow ratings. They many times will run out of payload long before they hit the tow rating. Good luck.
silver surfer
South Brunswick, NJ
Agreed. Payload is not very high on the Ram half-tons. IMO, your rig is way too heavy. You might be ABLE to pull it, but I can almost guarantee you won't enjoy the experience.
The payload maybe on the low side on Rams but it is not the determining factor for towing.
The numbers you need to concern yourself with is the the truck's GCWR and the GAWR. Even with 3.92 gearing, that puts you with about 10K of weight capacity, whether it's in the truck or on the trailer(see why payload is irrelevant?).
If your above weights are accurate, odds are you'll be way over once you load up everything you need to take.
Take your truck and trailer to an actual scale loaded minus the RZR and see what everything actually weighs.
sticknstring
Used to pull a 10k loaded horse trailer with my 2013 1500 Express. Never had an issue.
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
You were probably way overweight. But glad you had no issues. Did you ever weigh your rig?
sticknstring
No. Had enough power to pull it uphill, and great brakes on truck and trailer to stop it going downhill. As long as I have those two things (braking being most important to me) I don't worry about it.
Markcuda
Eau Claire Wisconsin
2026 Longhorn 4x4,short bed,22s,H.O twin turbos.
3.0 I6 H.O. Twin turbos.
If you never scaled the trailer, then how do you know it was 10.000 pounds?
Markcuda
Because I know how much my horses weigh and I know how much the trailer weighs. I also know simple math.
Yup, I was 27 years old once also.
Farmer Fran
Earth
2025 Limited Longhorn
SST H.O.
Goto www.Ramtrucks.com
Towing Guide
Look Up my Vehicle
Drop in your VIN and report back with the 2 numbers shown
novelmike
Central California
I was told once that the sticker on the driver side door jam is not the total payload capacity. It is the people and cargo capacity for inside the cab of the truck.
My door jam sticker and the RamTrucks.com numbers are not the same max weight. Is anyones? So is it true the door sticker is just a max weight for inside the cab?
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
Incorrect. It includes all weight in the truck. In the cab and bed. My truck has over 3100 lbs of payload on that yellow sticker. That's the whole ehchalada.
Acording to the ram trucks website where you run your vin for payload, i have over 3200lb according to that. Right , wrong or indifferent, my understanding is that the yellow sticker is more accurate as that is printed at the factory when the truck is assembled.
Remember that anything you add to the truck reduces that number. Side steps, lift kits, bigger wheels and tires, aux. Lighting, push bumpers, etc.
That stick and the website both give bad information. According to the yellow sticker on on door, I can overload the payload with the just five passengers in the cab. According to the website I have no payload and a towing capacity less than a gasser V-6
If you want the correct information, look up the SAEJ2807 towing charts for your truck.
novelmike
Central California
Wow! So if the sticker means total weight of payload and people in the cab and bed of the truck, a Ford Ranger has a higher payload capacity than my truck.
AND the Honda Ridgeline has my 5.7 Hemi beat by a lot too!
Thats it, I'm getting the heat gun out and removing the sticker.
Farmer Fran
Earth
SST H.O.
Not sure what's going on with all your trucks but all 3 of my Rams door stickers and RamTrucks website match identically.
BossHogg
Navy Badge Law Enforcement
Oakland Township, Michigan
6.7L Cummins
It isn't the determining factor but it is certainly part of the equation. If the tongue weight of the trailer contributes too much weight pushing the payload beyond the truck's rated payload then it is an issue. You got to remember, there is more to towing and payloads than axle ratings. Research the criteria used for tow ratings in the J2807 specification RAM uses to rate their tugs.
The placard in the driver's door jamb area is accurate for that truck. The placards are adjusted for options that have been added to the truck, for example, a sun roof.
