2014 Tradesman 3.6L
Faith
Issues: Mpg readout bounced to 99 mpg the next day -
Getting code P1D99
Getting code P0731
Getting code P0303 - replaced
Won’t go above 15 mph
Shifting with a jerk but able to shift most of the time
Driving loses power, used to be able to just restart and it would be fine. (2 times in 4 years)
Mercedes transmission
Performed reset three different ways. Disconnect negative battery cable; position 2 hold down gas for 30 seconds turn off wait two minutes restart; pulled fuse and codes will not go away
Quoting over 6,000 to get repaired. Pretty sure I am getting ripped off. Any help would be appreciated.
Fuel issue? Computer issue? Transmission issue?
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Getting code P1D99
Getting code P0731
It sounds like the truck is entering Limp Mode. Did they say it was the transmission?
KAKA
