woodshew
Hello all,
New to me 2015 Ram Hemi and it got hot last night. I managed to get home and upon investigation i found the fan fuse removed. The next morning i jumped the fuse pins and find the fan is always on if fuse is in. (the fan is bad you can here and smell it) i checked the following
low speed relay out - fan still always on
high speed relay out - fan always on
both relays out - fan always on
high pressure a/c disconnected - always on
from there brought up to operating temp
bottom hose hot top hose cold
removed temp sensor connector (cluster indicated full hot) thermostat engaged and top hose got hot
temp sensor reads 0 OHMS at all times hot and cold
ANy ideas?
ANy ideas?
