2015 Ram 1500 2wd leveling
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
How tough was it to get the spring back in?
Had a local shop that does all the new dealers lifts do install. So not sure. They put them in, I put tires on and drove for alignment.
satxwy
Pentastar 3.6
It's a PITA! Use more than one person and alot of patience.
Not what I wanted to hear, but thanks. I installed some on a 98 GMC and they were a PITA, I was hoping it was easier on the Ram, maybe a different coil bucket design or something.
How much did they charge?
Graygoose
Oklahoma
Convert, for now.
small
Like $150 for complete install.
madrock
Getting the 2WD coils back in can be a royal PITA. When I had a 2WD Ram, I couldn't get it in so I went with spindles instead.
You could try coil spring compressors (they go inside with a plate at the bottom). Regarding the shocks, you can run the extenders but it could limit travel. A lot of people go with 2500 front shocks.
satxwy
Pentastar 3.6
Just ordered 1.5" Daystar spacers. Still undecided if I want to install them myself or find a shop locally. Amazing how cheap you can get them.
FireHemi89
Did you ever install it? How much lift did you actually get? And did it change the ride? Thanks!
Aixmighty
2014 RAM 1500
V6
I installed 2.5" spacers on my 2wd 1500. Definitely need to use spring compressors to get them back in.
Aixmighty
2014 RAM 1500
V6
Thanks, I went with Top Gun Customz.
FireHemi89
Which model number or kit did you go with? Don't see a 2.5in kit for 2wd on their website. Thanks!
Stock13
Hello everyone am new to this forum, I got a question about this, I did a 3 inch level on my truck but now the ride is too bumpy, anyone know what I can do to avoid that
SwollenMonkey16
For all those running 2500 shocks, where do you get the bottom adaptor for the 2 screws and how do you press it in?
PassivAggressor
Bad news, either take the spacer off and go smaller or run a longer shock. If you run a longer shock you will hear stuff banging. That would be your upper control arm and your coil bucket.
I don't know about the adapter but usually just grind down one side a bit and push it in the bushing.
BigHorn407
Bouncy front
What did you end up doing with the bouncy suspension after installing leveling spacer. I have the same issue 15 bighorn 2wd
Mambo Dave
Subscribed. I need to do something tot he front of my Tradesman. It drives me nuts during oil changes being that low.
