2016 2500 RAM - where is the TPMS module????
Bob Rice
Atlanta
I hit a bump at low speed (25 mph) and now my TOMS light shows that the module is no longer working. It flashes for a minute and the turns solid. The tire pressures read correctly still. I thought that maybe the bump jarred it loose, but I cannot find it anywhere. I’ve looked in the are in front of the driver’s side wheel well with no luck. Where is the TPMS module located on a 2016 2500?????
B
Bob Rice
Atlanta
Check out this video. Should be in the same place.
Thanks! I saw this video and looked there, but could not find it. I crawled up under the truck and looked, then took pictures of the area just in case I wasn't seeing it. Does it make a difference that it is the 6.4l Cummins?
Lomza96
Mount Prospect, IL
Hey, did you find the location of the module? I can't find it either on my 2015 RAM 3500 diesel
OasisNinjaBat
