2016 Ram 1500 TPMS Sensors Need help
hhhjohn
Toms River
3.6L
So I have 2016 Ram 1500, 1 out 4 sensors read and it is the drivers side. I had the sensors tested and all 4 are giving off Rf single and read on the tester. It does have aftermarket tires and rims on the truck. How do I get the rest of them to read so my light goes off. Please help I wanted to locate the TPMS module and unplug it to see if that helps but can't find anything on line to locate it. Any help with this is appreciated. thanks
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
They may not be set to the correct freq required for the truck. They may be giving off a freq, but is it the correct setting?
Did the aftermarket wheels come with different sensors? And your sure they were correct?
hhhjohn
hhhjohn
Toms River
3.6L
Yes the sensor did come with the rims. Just weird how one works and the others don't. How do you check and change the freq to see if that is it?
madtrucker2016
New York
don't know if true but a tire guy told me to reset them you need a magnet with a circle with a opening and you place the magnet over the stem and it resets it I found a magnet like he described but have not done it no need yet
Graygoose
Oklahoma
Convert, for now.
small
Probably have to have a tire shop check it, or I bought OEM sensors from these guys, exact sensors without the price.
https://www.tpms.com/
PoMansRam
East Aurora NY
I take it these are not OEM sensors. If they are, they need to be 2015+ to work and they require no programming. Aftermarket sensors could be all over the place and will require programming.
