buckeyexx
- Jan 25, 2015
- 768
- 797
- Location
- Ohio
- 2016 Power Wagon
- 6.4 Hemi
Well I started the last couple of weeks just doing a simple thuren spring and shock leveling kit and ended up needing to replace a whole lot more. I knew I had a bad ball joint on the passenger side that I started to replace but found a bad u-joint also. Truck felt as if it was in 4wd when you turned the wheel in either direction. As they say u might as well do both sides if your going to do one so I ordered all new ball joints, u-joints and hubs for both sides and had to replace a rotor that was froze to the hub.
I’m not upset that it all had to be done but when it rains it pours and the truck drives much better just a little lighter in the wallet. Lol
