2017 Rack and Pinion Failure from Boot?
Mcaba
2017 1500 5.7L. I have a rack and pinion that goes out and the red steering light comes on my dash. Then I will turn on the truck later and it would be working fine. I want to explore all options before I grab another one. When I took off the part I noticed that one boot was broken. Assuming that there is gunk in there, would that be enough for the eps module to sense a fault and cause the shut down of power steering?
chuth10
Minnesota
Did you ever get an answer to this, or find out any more information? Going through a similar situation.
Ken226
Washington State
Mine went out due to a torn boot.
Especially if/when moisture migrates in to the main circuit board.
It's designed and assembled in a manner that makes it very difficult to repair, and there is no availability of replacement electronic components.
Replace it with this part#
brixten
