Charles Ferguson
The low beams on my 2017 Rebel have ceased to function. Both quit at the same time so I don't think burned-out bulbs are the problem. High beams and fogs are working. Instrument panel says left low beam has failed. I have a cheap OBDII code reader but it returned no codes.
I am 2nd owner of this 2017 Rebel. As far as I know everything is factory equipment except the wheels/tires. I think the headlights are factory original. I can't tell if the the vehicle has Premium Bi Halogen Projector Headlamp option or not. The truck is loaded (Ram boxes, nav, sun roof, etc.) so it seems likely. I will try to attach a photo of the headlights. The headlights are *VERY* bright and are very white (not amber). I have LED headlights on my Jeep and these Ram headlights are at least as bright and the same pure white color temperature.
I thought maybe a blown fuse but as far as I can tell this vehicle does not have fuses for the headlights. From what I have read in other forum posts, some models of Ram have a TIPM, which monitors current to the lights and throws a code if they draw too much current or not enough current. I also understand FCA had class-action lawsuit about the TIPM in prior gen Rams. I googled the TIPM and it looks like it is built-in to the power distribution module (the fuse box), is that correct? I have also been reading that it can be reset via OBDII but you have to have the FCA-provided software. Is that correct? Would the TIPM shut down both low beams because one bulb was malfunctioning?
FYI, the FCA-provided software ain't cheap: AlfaOBD $49 on Google Play store + OBDLink MX+ Bluetooth, $100 on Amazon = $149, OUCH!.
Thanks in advance for any advise offered.
Apologies if this has been posted elsewhere. I couldn't find any other posting where the owner didn't have after-market headlights or a much-older Ram.
