2017 Tradesman 3500 remote start
Chad_Pedersen
Batavia
Cummins
Installed the mopar kit, switched the overlays onto my existing keys and used alfaobd to add remote start and the hood sensor.
Remote start isn’t working. Do I need to reset the RF hub? If so what app is the pin puller? Dealer won’t budge on charging $50.
1500ram12
5.9L Cummins
Yes you need to reset the rf hub.
It's the Chrysler pin puller app
2018 2500 6.4L Hemi Tradesman
1990 5.9L 12v Cummins W250
C
Chad_Pedersen
Batavia
Cummins
That worked. Picked up a tablet with android and reset the RF. Worked immediately!
C
Chad_Pedersen
Batavia
Cummins
Is there a way to eliminate the horn honking when using remote start? I press the door locks (honks) then hit the remote start button which causes it to honk once, lights flash and then one more honk before starting up.
1500ram12
5.9L Cummins
Yes. Either through the radio. I think it's under doors and locks or maybe lighting. I forget exactly but it's not hard to find. Or with alfaobd under customer settings. I don't have alfaobd with me
clifford15
RI
CTD
In AlfaOBD look for Cust.Prog.Features - Sound Horn With Remote Start. There is a search feature in Alfa so you could focus on “Cust” to drill down to the correct area.
C
Chad_Pedersen
Batavia
Cummins
Thanks! After you select your vehicle what is that under? Body computer, or something else?
