2018 3500 w/ rear air ride/self leveling air bags...Lift Level Ideas
Robert Lamothe
Massachusetts
Cummings 6.7
I can't seem to find what I should use. I pull a real heavy spray foam insulation trailer daily. Please help!9166358B-AF7A-4A6F-8D1D-41C2543E4DC1.jpeg
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Gas or Diesel?
Check out Airlift https://www.airliftcompany.com/
Their WirelessOne compressor set up work real good, you can have preset pressures and even has an app for your phone.
Robert Lamothe
Robert Lamothe
Massachusetts
Cummings 6.7
normally we just lift the fronts using new longer coil springs and longer shocks. That will give you Level. Are you looking to go higher in the rear?
Not if that works! Prob go 2.5 or 3” to level in the front and which would you recommend?
anything else that should be done after the leveling to keep the tires good or keep everything Aligned?
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
In that case do with the 4” BDS kit that retains your factory air ride. This will have all the brackets to relocate everything to keep your geometry correct. And yes an alignment is mandatory
Robert Lamothe
Robert Lamothe
Massachusetts
Cummings 6.7
Actually maybe I don’t have air ride I only have the air bags in the back.
Prob called something different maybe rear air leveling. That prob changes a bunch of what you have told me
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
No we are talking about the same thing. Different terminology,
RJWTX
If you can swing it the AEV 3" is what i run, I run 40s with the AEV fenders. rides great, has option for the factory air bags which is what i have also. I have the 30K rated truck switched from duals to singles.
topherztoyz
