2018Hemi
2018 Ram 2500 6.4 Hemi 66RFE transmission
Left Ohio end of October after having my transmission serviced. Got to flordia and seen spots on concrete pad. Front gasket of transmission pan has a slow drip, checked all bolts and all tight. Called shop that did the work and was told to keep a watch on the fluid and add as needed and they will tend to it when I get back home in April. So question is it’s right in between the cold check and hot check. How much fluid do I need to add to bring it up to full.
Thanks
Thanks
