2018 8.4 upgrade issue
Athlium
Tacoma, WA
3.0L EcoDiesel
So I was able to finally sourced a 2018 8.4 to upgrade from my 5". Backup Cam works.. didn't know that new Bezel wouldn't be compatible with wiring of old bezel so working on getting a harness.. so I currently can't get into dealer mode to find out what FW it's on.
Now.. when I try to connect phone to it, I get communication error 8 on my phone..
Truck - 2018 Trademen
Radio PN - 68331635AK
Phone - Samsung Galaxy S20 FE
Interestingly enough.. they said the truck that the radio was out of was 2018 (VIN Showed 2018 truck) but the Manufacture Date is July, 2020 (could have been factory replace I suppose)
Using OEM samsung cable and several other after market cable. all got the same resultes..
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Try updating Google Play Services and/or the AA app on your phone.
^^^ what he said, also delete any pairings on the phone and the radio
Athlium
Athlium
Tacoma, WA
3.0L EcoDiesel
phone is 1 week old.. everything has been updated to the latest version.
all old phone info has been deleted on radio.
someone mentioned the issue might be the hub? My hub has 1 usb plug with usb symbol which does work with a flash drive full of MP3s, other plug says USB and seems to only work for charging. I'm gonna get the dual usb w/ dual usb C and see if that fixes things..
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
I've had both errors. Its always been software related. If you're sure you are updated, try rolling back to previous version if Android Auto.
Axefall
Las Vegas
V6
68328704AD
If you had the 5” radio you need to upgrade the media hub for CarPlay, not sure if AA needs it as well. AA might work but only on the right port.
Athlium
Athlium
Tacoma, WA
3.0L EcoDiesel
68328704AD
AA did not work on either port.
Axefall
Las Vegas
V6
For what it’s worth my 21 Classic didn’t need a harness. The usb hub was a direct plug and play.
tron67j
Maryland
Just asking, do you have the media port in the arm rest storage compartment? That is where I have to plug my phone into. I also have a Tradesman with upgrade to UAS radio.
Athlium
Athlium
Tacoma, WA
3.0L EcoDiesel
yes.. Dual usb port with Aux in the arm rest storage compartment (Jump seat console).
Hub is 68322813ac. Left is media connection, right is USB power only
Which model UAS do you have? what FW? and which phone?
jazzyjavaz
South Georgia
2013 RAM 2500 SLT
Cummings I6.7
Very curious to know the answer. I have the communications error #8 and have the same phone. I used a S8 and S9 and same issue, but my iphone XR works fine with carplay. I acutally have the hub from a 2019 jeep Compass.
Axefall
Las Vegas
V6
That’s the wrong wrong hub 100% it won’t work. You need 68328704AD . You probably don’t need a harness and it will be a direct plug and play swap mine was.
Axefall
Las Vegas
V6
The good news is it took me 5 mins to swap mine. Pull the cup holder out, remove the fabric around the corners to access the bottom of the jump seat arm rest this will give you access to the two tabs under push them in, then push in the two tabs on top. You should have two holes that give you access to the tabs when the arm rest is removed. I literally just went through this process PM me if you have any questions or ask them here.
Arturo Rojas
