2018 ram 1500 limited 2wd
Prayinmantis
I have a 2018 ram 1500 limited 2wd w/air ride that i am trying to lift. I've been told I can use the bds 4in lift for a 4x4. Is this true? Does a 2wd and a 4wd have to same suspension setup?
co-pilot
houston,tx
Nope!!!!.....MaxTraxx or Rough country make 2wd lifts ... not sure if BDS does but def. not same as 4x4
Riverside California
2018 2wd
HEMI 5.7 Revolution 4.88s
You can only use the rear , you would still need the spindles up front to lift it, don't use spacers lol ...
P
Prayinmantis
Do you know where i can get the spindals or a kit that works for my setup
2018 2wd
Maxtrac is what i went with 2wd. I got the 7in kit they have a five also that looks really clean with 35s. the 7in fits 37s
Are you going to regear now ? ...lol .... If you do , you are going to see a huge difference ... I want to get the
From Maxtrac or CST suspension ...they both sell the spindles by themselves ...
Joshua Collins
2011 & 2023
6.7 & 5.7
Are you wanting to get rid of the air suspension? They do sale lift links to adjust the ride height on the truck that are a simple install & adjustable.
P
Prayinmantis
I don't mind losing it if it do not throw any codes or dash lights
P
Prayinmantis
How much does it cost to regear
2018 2wd
Now do you have both front and back lift from maxtrac
I do yes, with the fox shocks all around ... I did have to add the carrier bearing spacer kit which you will also need to stop vibrations do to the incorrect angle of the drive shaft ...
Also make sure they add the 1.5 spacer in the rear or you will be squatting ...
This is the carrier bearing spacer kit you will need :
P
Prayinmantis
Now this fits factory air ride? Or just regular 1500 2wd
