2018 Ram 2500 Knocking
rayelee
louisiana
6.4 hemi
I have a 2018 ram 2500 6.4 hemi knocking I think I'm not sure I did a lifter replacement and relapped the valves for my hemi tick to go away now for a new noise to come up.
I have a video attached
2003F350
6.7 CTD
Didn't watch your video, but are you sure you lashed the valves properly and have good compression on all cylinders? Why did you do a lifter replacement? Did you have bad ones or just to head off the potential failure that might not happen? Did you re-use any bolts or put in all new?
Daw14
South Florida
Sounds like the valvetrain to me, recheck to be sure all the pushrods are seated properly.
R
rayelee
louisiana
6.4 hemi
I'll be doing a compression test later today and see what it is but I think its fine, I had one bad lifter making a lot of noise wasn't bad enough to damage cam, I relapped the valves do to having a intake valve not seating well. I used all new bolts
