2019 1500 Classic security module location
1500ram12
5.9L Cummins
I believe they are behind the radio
2018 2500 6.4L Hemi Tradesman
Ramm5.7
So Cal
2019 Ram 1500 Classic Bighorn
Where might I locate it?
On my classic they are behind the dash next to the steering column on the left side. The instructions for the harness state to remove steering column plastic cover but i just contorted and found them there up high
1500ram12
5.9L Cummins
You both are referring to the can connector location not the actual security module. The module itself should be located behind the radio.
1500ram12
5.9L Cummins
Found this diagram. That's for the DT (new body style). The classic (DS) is based on the 4th gens so as I stated it should be behind the radio
1500ram12
5.9L Cummins
It's going to look something like this. I'm trying to find a pic of the location but am striking out so far
S
Silver19CLassic
Phoenix Metro
I found it! I thought it was going to be a wire hanging somewhere. I got it unscrewed and out. Hooked my cable up and about to start messing with DRL on.
Thanks for all the help guys! And it was right behind the radio.
HEMI-FI
Active Duty Air Force ( B-2 Hydraulics)
Warrensburg Mo.
Well installed the bypass, that was a pain, need tiny hands, waiting for android tablet to charge, what cool things can I change with my ALfaOBD?
1500ram12
5.9L Cummins
Post 1 in the alfaobd thread has everything you need to know
Make sure you download your stock log configuration before making changes
glsander
