2019 1500 Won't start and towed to dealer
MacNH
New Hampshire
I'm band new to this forum. I got my truck 16 months ago. I was asked to self quarantine myself for 14 days. on day 11 I went out to start my truck. It won't start. It won't open the doors. try both FOBS. open door using the key. Light and everything works dashboard, headlights, interior, bells, locks. Tow driver said this is the second he's towed with the same issue?
I called the dealership after 2 days and find out that the RF module took on water and shorted out. They then told me it's behind the seat? Anyone else have this issue? This doesn't sound normal and if it is, then it shouldn't be.
I just got a call and it's ready to be picked up.
Love what I found here.
Thank you
Mac
turkeybird56
Central Texas
Thank you
Mac
Haven't heard on FOB issue. There have been some issues on leaks into Cab, either from Antenna area, rear window, sunroof, water getting in behind seat and onto carpet rear floor area and behind rear seat. I hope U made sure that THEY not just fix module but RESEARCH and take care of LEAK also. Sometimes, those vents behind the seat have leak issues also. MAKE sure U stay on dealer and get leak issue investigated and repaired...
RamCares
n/a
n/a
Thank you
Mac
Hi @MacNH - If you are in need of any additional support after picking up your truck, please do not hesitate to reach out to us. Our team is always a private message away and more than happy to assist!
Mark
RamCares
KQQLCAT
Had similar issues at 900 miles and it was a bad battery. Had to have it towed out of my garage.
RamCares
n/a
n/a
If you are ever in need of any additional support down the road, please do not hesitate to reach out!
Mark
RamCares
Gregory McKinley
Piedmont, SC
5.7 E-torque
Guys I had the dead battery issue also last week. I dropped off my truck last Monday and Just getting it back today. They replaced the battery under warranty. Fixed the check engine light issue by flashing the TCM. I had the radio at times, drop down on volume. They did the USB update 184824. And this seems to be fixed. The last thing I wanted checked was my tail gate not releasing. This is still not fixed. Was displeased with the customer service with this location. Took entirely to long and no communication. I had to make the calls to get info updates on my truck!!!! Not to mention I had an appointment set for last Thursday at 0830. Each time I called they would have to call me back with the update and would be 30 to 45 minutes later. If I had not called today my truck would still be there!!!!.... Very POOR!!!!! Big "O" Dodge you should be ashamed!!!! At least I have my truck back and driving it now. I do enjoy having this Truck!!!!
M
MacNH
New Hampshire
I got the truck back and the RF module was in water. They replaces and resealed the area. They found NO EVEIDENCE of water getting in. They tried to tell me that I dropped a woater or something back there. The RF connection was carroded and They cleaned it up and it worked great. I never got to discuss it with the dealership since I had to pick up after hours. I'll be there in a few weeks for an oil change and discuss it then.
Thank you for all your valuable information.
Mac
RamCares
n/a
n/a
Hi @Gregory McKinley - I am very sorry to hear that this was your experience working with your dealer, as it is certainly not the treatment we expect for our customers. If you ever have to work with a dealer again down the road, please do not hesitate to send us a private message so we can get you connected with a case specialist for further support through that process.
Mark
RamCares
TimboRam77
I've documented 6 failures to start with a dead battery with my local dealer. The most recent was a last opportunity for repair visit. The entire 12'' radio was replaced and it has started ok since. However the weather has warmed and I mostly had the problem during cold temps. The behaviour of the electrics have changed since the replacement. For example everything shuts down quickly now after engine stop. Previously gages stayed powered for a longer time.
RamCares
n/a
n/a
Hi @TimboRam77 - I regret to hear of the trouble that you have had to experience with your truck. Please do not hesitate to follow up with us via PM if you address this any further with your dealer and additional support is needed for that process.
Mark
RamCares
Wcarll
I also had a dead battery on my 2019 Limited, less than a year old. Had to have it towed to dealer. I have a charger but it would not take a charge. Dealer replaced battery but today the check engine light came on again. I suspect low voltage and that the air suspension pump goes off regularly draining the battery while I stay isolated st home these days. I bought a trickle charger and it is charging now. Hopefully this will fix the problem.
Duane Pipes
FL
That pic is bad to look at daym
ARRazorback
Spring Tx
I know this is an older post, I am now having the same problem. My truck has been sitting without moving for about a month now. I went to the store yesterday and it rained last night. Today I went to start it and it wont start. I put a battery charger on it and it said it was 85% charged. I let it charge to 100% and still no go. it acts like everything is working it just clicks when it tries to start. I bought the truck in dec 2018, it now has 42k miles on it. I wonder if it will be covered...
Trying to call dealer now.
RamCares
n/a
n/a
I apologize for the trouble, @ARRazorback. If this is something you decide to address with your Ram dealer, we would be more than willing to escalate a case on your behalf to a specialist for further support through that process. Please do not hesitate to follow up via PM with any additional questions.
Mark
RamCares
mikeru
Super Moderator
Super Moderator
The Palouse
2020 Limited
Mac
Something doesn't make sense here. They replaced the module and resealed the area, but found no evidence of water getting in? So what exactly did they reseal then? Also, it's unclear to me what your truck is. A 5.4 isn't an engine option for any 2019 Ram truck.
There seems to be two main culprits for water leaking at the back of the cab on 5th gen 1500's, although there have been other causes as well. The most common is probably the 3rd brake light gasket. The other is a cracked or leaky rear window frame. My suggestion would be to check both of those for signs of leaking. Hope I'm not breaking any rules here, but there's a ton of info on these problems over on the 5thgenforum.
ARRazorback
Spring Tx
Mark
RamCares
I took my truck to the dealer service center. They fixed it and wanted to charged me >$3000. They have created a ticket with Chrysler to see if they will pay for it however, we have no response yet. What would be a good method for me to proceed?
I told them about your reply and they said they have already done the repairs. I just cant pick it up until they are paid for...
They said the rain came in the back glass, and flowed to the RF HUB which now may needs to be replaced. The speakers in the almost brand new truck are weeping. They said there was a TSB about it however, since my truck has 48k miles it was unlikely it would taken care of.
They said it was not a recall issue because it was not safety related.
I bought this truck Dec 2018. I then moved from Arkansas to texas and put a substantial amount of miles on it in a very short time due to the move. I have taken great care of this truck and have always been a loyal Ram / Jeep Customer. This time I went all in and got the beautiful Laramie Longhorn. I have owned 6 Ram/jeep vehicles. This is the first time I feel like I am getting screwed over.
Musky Mike
NC
Sorry to hear your having this problem, the water intrusion is a known issue...search the this site.
RamCares
n/a
n/a
View attachment 221799 View attachment 221800
I apologize that you are experiencing this, @ARRazorback. Just had a chance to respond to your message!
Mark
RamCares
ARRazorback
Spring Tx
Just wanted to post an update on this. My vehicle was outside of limited warranty. But RamCares and my FCA Agent took care of it. It took a few weeks but it is all taken care off and I pick up my truck shortly. Cost ended up being crazy. They had to replace RFHUB, Headliner, Back Glass, and Starter before it was all said and done. It had a cost of >3k Thank you RamCares for taking care of this!
oldfart59
green lake bc
my 2019 ram 1500 sport had the rf get wet from the window leaking. the truck would not start the dealer replaced the back window all good my dealer in 100 mile house bc was awesome
