northvibe
Alrighty. Bought the truck new, had line-x do the bedliner and then some time later had some blue screen/flicker when backup camera would go on. Had the dealer check it out under warranty, they "fixed" it and now it is back
When I wiggle the connector/loom between the bed and the tailgate, it will sometimes come back.
I took my tailgate off, unhooked the harness from the bed, removed some of the loom/tape, don't see anything noticeable. There is some metal tape on 3 wires that looks to be shielding for the camera wires. I ordered the harness for the bed to camera as a just in case. I have removed the tape back to the first plastic clip and things seem fine. I haven't used my DMM to verify continuity when the wires are moved. I am waiting on a neighbor to help watch the backup cam while I mess with the wiring loom to see if it is a certain spot.
I was hoping to find a bad pinch or solder joint I could patch and waterproof. The back of the plug does look like some corrosion is happening on the 3 wires clipped (not used) and if that spreads could cause issues inside the connector. I see that A LOT in pinball repairs. It seems like it happens after rain(ing). When the tailgate is opened, the wire loom "looks" pinched between the tail gate and bed, but it still can be moved up/down.
I'll be trying to troubleshoot this harness today, add dielectric grease to all the plugs and try to clean up that green/corrosion on the back of the one plug. I'll also check the plug under the truck. The camera plugs inside the tail gate felt and look good.
