2019 Dodge ram alignment
S2000gtx
Good afternoon everyone I have a 2019 Dodge ram bighornwith the limited black rims.
I just bought brand Perelli tires from Sam’s Club and they were installed this morning and I took the car to a tire shop to have it aligned.
Please see the attach report. The after column doesn’t look too bad, but there still in red . I wasn’t sure if the number were normal for this vehicle
rzr6-4
nebraska
'09 2500
I'm not one to get all up tight about perfection, I mean I've definitely seen worse, but if I'm paying for it to be aligned then it better be aligned when I get it back. Not 3 things still out of spec.
Where did you take it?
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
Caster is not going to wear out your tires and the rear is non adjustable. Looks pretty good to me. Better than you had before. I've seen much worse
S
S2000gtx
Thank you for the feedback and I took it to tires choice in Florida
S
S2000gtx
Wait so the rear camber can't be adjusted ? Seems strange the left side is in spec and the right side is red .
rzr6-4
nebraska
'09 2500
Solid axle so no way to adjust camber, I'm sure there are false reading scenarios but if it is actually off then often times that means your axle housing is bent. Everything on the front however is adjustable, and should have been corrected.
S
S2000gtx
Got it thank you
