2019 Leveling Kits
ksn240
Is your speedometer off? I'm guessing the headlights are a tad high to
Speedometer is off. Dealer says they cant fix it. Hypertech has a programmer out for it but dont know if I want to worry about it or not. If the speedo shows 75 I am really going 80.
As for the headlights, they seem fine to me, and I haven't had anybody flash at me to let me know they are bothersome for anybody else.
Kevin C
Livermore, CA
Did the 2’’ rough country kit completely level your truck?
I have this leveling kit and there is still a very slight rake (hardly noticeable) of about 1" (the rear was originally 3" higher than the front, now 1" higher).
jimh4662
South of Pennsylvania
2019 RAM Laramie Longhorn C.C. Delmonico Red PearlCoat
Here is Readylift
2019 Ram 1500 4WD 2 inch Leveling Kit w/ new Tubular Upper Control Arms
Front strut extension leveling kit. Before and after installation.
alex_5_7
Need some help guys... I just bought a rebel and I contacted readylift and they said their 2 inch leveling kit with uca's is not compatible with the rebel due to it having a 1" lift already. So I'm guessing the bilstein struts it has are what made the truck have the lift... that still doesn't make sense as to why there kit is not compatible. The strut should have the same bolt pattern up top and the control arm seems to be the same as any other ram.. and I asked rustybeltmechanic and he said the mopar 2" lift will not be compatible either... some help would be great. Here is a pic of my truck. The rear is 3" higher in the back to the top of the wheel wells
Ben33
Georgia
None
None
Kevin C,
What offset do your wheels have? Love the way they sit.
Kevin C
Livermore, CA
Kevin C,
My offset is 0. Factory is like +18 or something. I wanted them to sit out a little from stock, not too much. The 20x9’s ended up just right for me with the 0 offset.
rrjjpp74
SW PA
Mine are 20 x 9 with 10. And theysit almost flushwith a 35/12.5/20
jrmitt808
New York, NY
its been done. https://www.ramforum.com/threads/lift-kits-for-2019-rebel.123627/page-4
