2020 Ram 1500 Reflector Headlight and Fog LED Install
Underground Lighting
Supporting Vendor
Do you have a 2020 Ram 1500 Reflector Headlight and need better visibility? Well here's some great News! We have a plug and play, error and flicker free LED Bulb that fits in the cover! Wait that's not all. It gets better, the 2020 Rams are easier to change out the bulbs compared to 2011-2019 Rams.
We have taken some pictures and will outline the basic steps needed to access the original bulbs.
Here are the Links to the Products:
LED Low beam for 2020 Ram 1500 with Reflector Headlight
https://undergroundlighting.com/pro...r-quad-reflector?_pos=10&_sid=ddfc003d8&_ss=r
LED High beam:
https://undergroundlighting.com/pro...0w-6000lm-pnp-led-headlight-fog-light-drl-kit
Led Fogs:
Step 1
Open your hood to locate the headlight low beam and High beam covers on the back of the headlight. You will see the high beam is very easy to get to in order to change out the bulbs. However the low beam is under the fender you can access from the top but is a lot easier to remove a few screws from the fender liner.
Step 2
Go under the wheel well to the fender panel. You will see there are 3 8mm Screws to undo and 1 push pin in the center of the fender liner. Than you will be able to pull back the plastic fender liner to get access to the low beam cover.
Step 3
Twist the cover off and unplug the low beam bulb. Then you can untwist the H11 bulb out.
Step 4
Put our led bulb in and twist it into the lock position. You want the led chips facing 3 and 9 o'clock. Push the black driver inside the headlight and put the cover back on.
Step 5
Put the fender liner back in place with the 3 screws and push pin. If you are doing the fogs skip this step and move to step 6.
Step 6
below the 3 screws you removed for the upper fender liner plastic, you will see 2 more screws. Remove those and pull back the lower fender plastic piece to get access to the fogs.
Step 7
Unplug the fog light bulb by pushing the red tab down and press and pull down and twist the bulb out.
Step 8
Twist our led bulb in and plug it to the oem plug.
Step 9
Put the Two fender pcs back. Re screw the 5 screws you removed and put the 1 push pin back.
Supporting Vendor
I forgot to post a picture of the led installed in the housing. So here it is. Fits inside the cover. 20201013_084319.jpg
Fatboy1989
