2020 ram bighorn wheels
Bighorn guy
Bloomington ind
Been trying to get a set of moto metal wheels to fit my ram bighorn, the store has brought in two different sets of the style I want, and neither one of them fit. Said it’s hitting on the brake caliper. Same size as the stock wheels 18”. Anyone else found out about this
The 18" size is the tire bead diameter. Given a rim design the inside of the rim may not be big enough to clear the calipers, It's not uncommon. If your really set on a particular make or design of rim, you may need to go with a larger diameter rim. Another possibility would be reduced the amount of rim offset/backset or use a set of spacers.
Bighorn guy
Bighorn guy
Bloomington ind
We had disused going to a 20” wheel after this mess. Unfortunately I have a set of 18” Toyo’s sitting there waiting on wheels to put them on. They got a set of fuel wheels coming that they guaranteed will fit on my truck. We’ll see. Hopefully they clear the caliper
mikeru
Super Moderator
Moderator Supporting Member
2020 Limited
Hemi 5.7L non-Etorque
Ended up with fuel wheels. Wrapped with Toyo AT3s Still had to use 1/2 spacers to get them to clear the calipers
No pics??? That's blasphemy.
If you wanted to run 18's you could have just gone with stock Rebel wheels like I did...
Bighorn guy
Bighorn guy
Bloomington ind
Truthfully. I never dreamed there would be this much trouble fitting a wheel to this truck. The shop owner and I learned a lesson on this one.
mikeru
Super Moderator
2020 Limited
Btw. There is a picture of the new wheels on it.
Sorry, my bad. I didn't realize the pic went with your next post. New wheels look great!
