2020 tpms threshold reprogram?
tnt2671
2016 2500 regular cab
2020 2500 6.4l just got my new tires and wheels and am looking for a way to lower the thresholds. is this posible in the 5th gen hd's?
Motoman501
Sparks, NV
Not sure if the 2020 is different than my 2019 but I was able to do it with a bypass cable and Alpha Obd. I didn't lower the thresholds but turned off the alarm system. My dash still shows tire pressures but no more low pressure warnings.
Sandevino
North Texas
HEMI 5.7 eTorque
I run mine at 60 front / 63 rear and hand no issues. What pressure are you wanting to run?
Orlando70
St Louis, MO
6.7L Diesel
I did just that. On the 19's you get a warning at 20% down from I believe 60 PSI. In other words at 48 PSI you have warning lights which by they way you cannot eliminate until you inflate back to 60 PSI!
They are folks out there who for a small fee say under $100 will make your set point of inflation whatever you want. I was told you cannot change the 20% threshold.
Motoman501
Sparks, NV
I would have to search for the instructions again but as I stated above I was able to disable the warning system so there's no need to set the threshold to any other pressure. I can view current pressure as normal in the dash but can air up or down as I wish without the low pressure warnings. I typically run 55 front and 45 rear unloaded.
