2021 Tail Lights
Jeffko37
Bentonville
I have a 2021 Laramie and wanted to update the tail lights to led like I did on the 3rd brake light. When I removed the assembly there is not twist out for the bulbs. Apparently the bulbs are internal. I suppose I literally have to replace the entire tail light assembly on both sides or is there some secret to opening them?
markabby
Monticello, Kentucky
2020 Limited
From AI:
To replace tail light bulbs on a 2021 Ram 1500, remove the two T-25 Torx screws on the inside of the tailgate opening, pull the assembly straight back, and twist the bulb sockets counterclockwise. Standard bulbs are generally 7440/7443, though some models may require full assembly replacement
Grams
2024 & 2015
6.7 Cummins & 5.7 Hemi
My tail lights are Behind me. That’s someone else’s problem.
I don’t worry too much about what’s behind me.
Unless it’s pursuing me.
In which case it depends on whether or not THEY have flashing LED lights.
TRK_GANG74
Navy Badge
Va, Hampton Roads Area
Pictures of your tail light will get you more replies and help. Please post some so we can see.
If there is no bulbs externally to twist out from the back and there is no removable covers (usually will have screws), then yes the taillights are sealed and they are already LEDs. The OEM LED taillights have a square wiring plug.
