2022 Ram Towhaul making engine race
SusanM
White Haven PA
I have a 2022 Ram 2500 6.4 and tow a horse trailer with it. While in tow haul the other day when pulling up to a light the engine was really racing and wouldn’t stop. Pulled over and shut it off and then it was fine. Is this a transmission problem?
pacofortacos
Any lights on? Define really racing - rpms?
S
SusanM
White Haven PA
No lights on and not sure about rpm’s but it was revving up. Have an appt at local dealer on the 9th for the radio recall and to check it out. Have to make two trips to Florida towing next montj
ramffml
ramforum
My first guess would be cooling fan too. The other possibility is that if you noticed it only when breaking it was probably just tow haul mode which by design revs your engine up to help with breaking; the high RPMs slows the truck down.
OC455
Central NY
Are you sure when you were braking, that the transmission didn't downshift to a lower gear to help slow down?
If the engine was really racing,odds are it would of been over powering the brakes,and you would of had a hard time getting it stopped at the light.As suggested it was probably the engine cooling fan.
14hemiexpress
6.4l
Tow haul will make you hold gears longer and being a gas engine it will rev higher than a diesel to make torque. Sounds pretty normal did it shift after the hill? Or would it never shift? When I had a 6.4 it would run 5k+ accelerating with my camper.
smittyd174
Halifax
Tow haul mode is a weird animal , holds gears for longer periods when accelerating sometimes too long . It also downshifts really quick when stopping causing engine racing to aid in stopping .Also these trucks all have learning transmissions and if you don't use tow haul all the time it acts a little wierd until it figures things out .
My 2016 ,3500 with the Aisian Trans took a good day of towing to work as it should .After that worked perfect for the remaing 6 days of the trip . Then it had to relearn for no trailer and then when it was time to head home it had to relearn tow haul .
