2025 1500- What is this 'tool' in glove box?
RamDiver
Marlborough, Ontario Canada
2021 DS
Not every truck has it, but lots do
Good call.
I never considered the spare as a theft risk.
Whenever all the crud stops falling from the sky over here, I'm going to move the spare wheel tools from the cab into the tool box that's locked under the Roll'N'Lock cover. :cool:
turkeybird56
Central Texas
Hemi 5.7, Non E Torque
Good call.
SO , if not a key for the winch part, and maybe/maybe not a spare tire lock, wat the heck does it go to????????
Maybe OP will report back on what it is via his dealership, tho I really doubt the "sales person" will have any idea.
ADDED: I had that issue when wife got her 2010 Ford. Was a bag of parts in the glove box like Mopar to cover up bed connections when tailgate pulled. But there was also a specific fuse in the bag and no instructions. TURNS out, you had to put that specific fuse in a specific fuse box slot to enable the 12V power for charging on the 7 pin connection. No where was that info available, listed, wateva, and I pulled that trailer for years and had no idea till a friend clued me in, wat a dumb boird I was. You know, plug in the 7 pin, all lights work, just not pay attention to detail, duhhhhhhhhhhhhh.
RamDiver
2021 DS
I swear, sometimes the manufacturers are brainless.
How could anyone know what these unidentified parts are used for unless informed?
I thought the link that BWL posted looked pretty obvious to me that it's the same piece.
There's just no way it could be used as a wheel lock key when the spec torque is 130 foot-pounds. :cool:
I thought that possibly ..
That on some Rams, like the Limited
that the Spare is a Special Limited FULL Sized Tire & Fancy Rim
That may be worth putting a Simple Lock on
The OP's Ram is a 2025 Tungsten !!
  • Brand:
  • SKU:
    82216081AA​
  • Other Names:
    Lock Kit​
  • Description:
  • Add the Spare Tire Lock to you vehicle to protect your spare tire and wheel from theft. This special Mopar exclusive key allows you to lower and raise your spare as needed.
    Spare Tire Lock helps protect against spare tire and wheel theft. Special key allows only the owner to lower or raise the spare tire.
Used on certain 2019 + Rams & Gladiators
mikeru
Super Moderator
Moderator Supporting Member
2020 Limited
Hemi 5.7L non-Etorque
Naw, the Limited gets a temporary spare tire unless you also get the Off Road Group. Our 2020 and 2021 Limiteds didn't come with a lock on the spare.
first time used on Ram trucks
2019Ram1500Big Horn, Laramie, Laramie Longhorn, Limited, Lone Star, Rebel, Tradesman3.6L V6 - Electric/Gas, 5.7L V8 - Electric/Gas, 5.7L V8 - Gas
first time used on Jeeps
2020 Jeep
GladiatorAltitude, Launch Edition, Mojave, Overland, Rubicon, Sport, Sport S3.6L V6 - Gas
TMFMK
