2025 Ram 1500 Adaptive Cruise Control Distance Meter
Canon38
New York
3.0 L
My 2025 Ram 1500 is equipped with ACC. I can activate it and it works properly. I can adjust the distance settings and that works. However, according to the video and the owner's manual, there is supposed to be a four bar indicator light on the dash to show how much distance has been set. My truck does not show that. Only that ACC is active.
My salesman can't figure it out, and RAM Hotline doesn't have an answer. I'm trying to understand it that's working as designed or if my indicator lights aren't working.
Timmerduder
Oregon
On my 21 power wagon it only shows it on the cruise control page on the dash cluster. It doesn't show it if you don't have the specific cruise control page up if that makes sense.
TRK_GANG74
Navy Badge
Va, Hampton Roads Area
Do you have a button like the one circled in the pic on your steering wheel? You should if you have ACC. Pressing this button allows you to select the desired distance for following.
Jrod
USAF 1997-2008
Virginia
2025 Laramie
SST SO
It shows up on the right side of my speed indicator on my 2025. The bars will turn green once you hit set or resume.
DanAR
Arkansas
Good to know about that adjustable feature. Mine is set a bit too conservative so I would like to adjust it a little. Thanks
