2500 bumper and grill
Northshoremb
Banned
Does anyone know if the 2500 bumper and grill will work on the 1500 if used in conjunction? Love the look of the 2500 front end because the bumper doesn't stick out like it does on the 1500. Just didn't know if the front end was the same other then the grill, bumper and shroud to swap
Sent from my SM-G900W8 using Tapatalk
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
This has been discussed on the forum a few times. If you do a search you'll find a number of posts on the subject.
You can do the swap but it's not a direct bolt on thing as the mounting between the bumpers/grille on each truck is quite a bit different. I'm not sure if there's a company that makes aftermarket brackets to do it yet... not that I've seen but it may be out there. You have to swap the bumper, grille, hood, and the little trim piece under the headlights from the 2500's.
RAMYOU
also 2500's have a different more I like to call it "confident" hood. Its the more tucked in bumper and the "confident" hood makes these HD front ends look sexy.
