2500 rear differential question
Bmarsh1605
Hey all I'm new to this forum and the ram scene!! The rear end blew out on my 95 2500 v10 and in exploring options to remedy this situation because I would hate to scrap it! Rather than rebuilding it, I'd like to just swap out the whole rear end with a used one. I know it's a different rear end as the 1500. Are they the same for the the 2500 v8/v10/diesel? Or where else may I be able to find a rear end to fit? I don't care about gear ratio or how strong it is for towing. Just want it to bolt right up and drive down the road! Thanks in advance!
mumbles84
5.9 magnum
cant use a dually you probally have the dana 70 dana 60 might bolt up the only diference is ring gear size i beleave the 60 is 9.25 dont know what the 70 your best bet is to get your diff tag number and look it up might be cheapper to rebuild verry desirable axles in the off road world making them woth up to $1000
mumbles84
5.9 magnum
found the diff info sticker its on the hood i was hanging a light on my hood when i saw it
