Suspension question.
Saig
Virginia
5.9 12 valve Cummins
I have a 1994 Dodge ram 2500 4wd with the 5.9L Cummins, when measuring from the bottom of the fender to the center of the hub of the wheel, the truck sits 4 inches lower on the front then the rear I would like the level it, but I am hearing that the front coil springs could possibly be tired, which is why it is so different from front rear I was wondering if anybody here has changed out the coil Springs and if so, what is a good recommendation?
