2nd Gen 12v Power Plug In
iSlacker816
Kansas City, MO
5.9 (360ci) Magnum
Is it possible that with alot of the pluggin in and unplugging the socket can somehow "wear out"? I bought a car charger for my phone last night and seems like it only works when I wiggle it around in the plug in...
ramhunter9
P-Star Jeep Wrangler
It is very possible . Or a loose connection on the back of the outlet
iSlacker816
iSlacker816
Kansas City, MO
5.9 (360ci) Magnum
Think I could pick one up from radio shack a parts store or would I have to get one from the dealer?
ramhunter9
Not sure on that one . Could get one cheap out of the pick and pull
ramhunter9
No problemo
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
If you don't get one at the pick and pull, a radio shack would work, just wire it up.
Badger
Bettendorf, IA
Lick all the metal contacts on the charger then plug it in. It will work like new
Rogan68
Lancaster, TX / Winchester, VA
6.7L Cummins G56 DRW 4WD
make sure your 12V power outlet contact (center bottom) is clean. also, try another 12 plugin and see if it works fine. could be the accessory that you're plugging in that is the culprit.
iSlacker816
iSlacker816
Kansas City, MO
5.9 (360ci) Magnum
Well the charger is brand new, I just figured the last owner used it alot cuz it seems loose like the actual plug in isnt snug
ramhunter9
We need a new section called " This ol Hillbilly "
ramhunter9
The one and only ^ ..LOL you crack me up
Badger
Bettendorf, IA
Lol well I would be honored to take the title of "this ole hillbilly"
iSlacker816
iSlacker816
Kansas City, MO
5.9 (360ci) Magnum
fine, don't try another item then.. LOL
I'd help you more, but you keep ditching me on MW3 ;)
Lol hey now, I wasn't ditching you. I had to get off the last time we played so next time you see me on shoot me and invite :D.
And i don't have anything else to plug in....
Rogan68
Sorry, all I hear is 'Blah, blah, blah'.. ;)
You can basically replace the socket with almost any socket, as they're fairly universal. That doesn't mean they're ALL the same, mind you..
Stagman
Sherman, IL
I'm not sure how our Truck sockets are constructed, but in others there are side pieces that can be pryed out along the walls of the recepticle. Doing this and also looking at the male end of what you are plugging in and prying out the side connectors if they are made in such a way to allow prying can help. Either/both will give you a tighter connection. The recepticles hardly ever go bad unless you burn them up with overload/short. However they do get loose over time and use.
Jay
alphaprojects
