2wd Level/Body lift
whothekcuf
Does anyone have pictures of a 2wd 2nd gen with level kit and body lift and also how big of a lift to fit 35s without rubbing?
DodgeTx
SEGUIN
5.9L Cummins, 5.2l v8
I think no matter what a 2wd will alway rub at full lock with 35s.
W
whothekcuf
I know you can run 35s with the fabtech 6.5 spindle lift but I didn't know if anyone has run them on a level kit and body lift.
MagSport
South Carolina
Couldn't tell you. On a 4x4, 35s rub the control arms but since you don't have any it's hard to say. You probably could with enough offset, at the expense of your balljoints of course.
W
whothekcuf
I guess 33s would be a better option.
W
whothekcuf
Do you think a body lift and leveling it would be too much for 33s? I read somewhere that you cant fit 33s on a 2wd with just a level kit.
Weezer
My truck goes in tomorrow for a ck and my buddy is a Dodge expert so I'll ask him
Sent from my LG-D851 using Tapatalk
MagSport
South Carolina
A level should let you run 285s safely enough. Granted you're also 2wd so there are differences in spring rates between 2 and 4. It depends on the level size I suppose, 2.5-3" level should let you clear 33s.
BBartow
New Port Richey, Florida
5.9L Magnum
Plenty 2WD run 2" levels with 285/75R16 no problem.
2.5" is max you can go with stock upper control arms.
W
whothekcuf
So if I do 2.5in level and 3in body I should fit 35s right?
