3.73 vs 4.10
scott lass 18
rocklin ca
2010 ram 1500
mine ya came with 3.21 had to give gears away no one wanted it ! did 3.92 and am very happy not towing much just load her up so lost maybe .5 mpg if even that seems mpg is same if my lead foot doesn't dent the peddle hehehe ! ow dont let dodge test anything pinon nut ask not too and ya they did it and I had to replace nut sadly dealer doesn't care what I want sadly wont stand up to the crap going on with my ecm ! work fine 10 years now all screwed up !
Timsdually
Jersey
Cummins
I have always had 4:10's and then in '09 bought a 3:73 because I thought I would get better mileage. Nope. Hated it. Felt like I had to floor it to get moving from a stop light. Went back to 4:10 in my '17 and I am getting a '20 next week and for sure a 4:10 was a must.
dhay13
I think you get better mileage in town with the steeper gears. Engine doesn't have to work as hard to get these heavy trucks moving. On the highway yeah the 3.73's would be better. How much? Dunno. Might save $5-$10 per tank I'm guessing. I am averaging 12.2 in mine since I bought it 12,000 miles ago (hand calculated). Probably 60-70% in town and about 500 miles towing 9000lbs.
A '20 with the 8HP75 transmission will have a lower final drive ratio in first gear with 3.73 axle than your '17 in first with 4:10 gearing.
66RFE first gear 3.23:1
8HP75 first gear 5.0:1 second gear 3.2:1
With the 8 spd you don't need to run as low axle ratio unless your increasing the tire size or need to tow heavy.
Pttrader
Like you, I moved up to the 2500 Hemi. I've towed 8400# with the 8 speed 1500 with 3.92 gears and it was pushing it. I have driven the 1500 8 speed with 3.21 gears, but did not tow with it
I towed 8400# with the 2500 with the 3.73 gears and the 6 speed. I thought it liked the lower gears 3rd and 4th on any incline. The 2500 was sold with the 8400# travel trailer(Package deal).
With the purchase of a 5th wheel 11500# to 12000#( loaded) I found me a slightly used 2500 with 4.10 gears and the 6 speed. Towing the 5th wheel I noticed it stayed in the upper gears (4th and 5th) when towing. That fall the truck was slipping and sliding around with those Firestone's so I got me some Cooper AT3 XLT's. Of course I stuffed about the biggest ones is could fit on the stock rims 295/70/18. These tires are close to an inch bigger in diameter than the stock tires 34.25 vs 33.23. I really like the look and the extra traction. My gas mileage empty went from 17.5 to 16 (roughly). It was never about gas mileage why I went with the tires.
When I towed the 5th wheel the next Spring it reminded me of the older truck (3.73s) with the truck favoring 3rd and 4th gears on inclines. I plan to move to 4.56s or 4.88s on retirement in the next couple of years. I don't put many miles on the truck and plan to keep it for several more years. I probably am at the limit weight/towing wise and doubt a 3.73 geared truck would be legal towing a 11,000 trailer.
There are other members that could chime in on that knowing allot more about the numbers and how much you can actually tow. Even though I have not driven the 8 speed in a 2500 I would go with the 4.10s since it will be easier when pulling the 11k trailer and gas mileage isn't a concern.
Speaking of gas mileage when I put the hammer down and tow near 70 my mileage is around 7 and up to 9 when I keep it closer to 55. My 5th wheel tires are rated at 75mph. Just sharing my personal experience.
Timsdually
Jersey
Cummins
Both trucks Aisin
Both trucks Aisin
The Asian isn't much better at 3.75:1 if it's behind gasser, it doesn't make much difference behind the CTD. The gear spread of Asian is light years better than the RFE66/RFE68 transmission but hopefully the ZF 8AP will behind the CTD soon.
bivyhunter
Idaho
Hey Guys - this thread has been super helpful but I’m not totally sure how to do the math to make my decision. I’m getting ready to order a ‘21 2500 HEMI. I would like to go up one size from stock tires to 285/65r20 which is 34+” tall. Is that enough to bump up from 3.73 to 4.10? Just not sure if that upsize in tire is enough to tip me to the 4.10?
80% of my driving will be in town/highway empty but 20% is towing a 5,000lb utility trailer or 8,000lb horse trailer. I’m trading in a ‘12 CTD 3500 that is more than I need.
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
6.4L HEMI
Scroll up and find sizing chart.
RAINCO
This is a great thread.
I got a 4.10 in my 22 6.4 Laramie 8sp about 7 months ago (10/2021); that was when the inventory issues were beginning to really tighten. I would’ve probably gotten a 3.73 but couldn’t find one in that environment.
NOTE: This was my first three-quarter ton truck so take my opinion for what it’s worth.
I had a POS 5.3L GMC 1500 AT4 in the shop 4 times with 15,000 miles and I had to get out of it so I did not have time to wait for inventory to improve. I felt like I was lucky to find the truck I wanted at MSRP while others were gouging at $4000 over MSRP. Approx $61K @ Lou Fusz St. Louis - great experience.
Still not 110% convinced which is the right axle, but I’ve got nearly 20,000 on this one and I love it. I wonder what a 3.73 would be like but I’m content with my 4.10.
Allow me to offer some opinion for those who may still be debating:
The extent to which I may be overpaying (if any) in hwy gas is likely very negligible and something that resale alone may earn back because this is a legitimate, occasional heavy hauler and plenty capable of the larger tires - two significant positives in the 2500 community. If you are towing heavy w/ any frequency or put on anything other than a stock tire on a 3.73, there is a potentially steeper slope of error (cost/regret) IMO. If you are doing both I think a 3.73 would be notably undesirable.
As mentioned before if you’re not above 12,000 pounds more than once or twice a month a CTD is worth nowhere near the up charge and maintence expense. Occasional over 15K is where for the 4.10 stays compelling. That is quite a bit of weight and more than a lot of people in 3/4ton trucks will ever hook on to. The 3.73 gets more debatable in these 2 scenarios. Even if i’m not using it like that the next owner might…
On stock tires (285/60r20) I get the following:
12.5-13.5 mixed
17 hwy
19 coming home from Colorado slow rolling at 65-66, but took it a while to get there.
NOTE: I had a 2014 F150 FX4 that could not get the same MPG. This is twice the truck of that Ford.
I really don’t tow heavy. I have an 18 foot utility that very rarely hauls near capacity.
I have a single axle utility that’s used very frequently. Fully loaded (5K gross) the MPG numbers really don’t move enough to notice vs empty. That’s not really a heavy trailer but I have it all the time w nick nack stuff. That same trailer would knock my prior half tons down to 12 - even a 2018 F150 XLT W 4.10s on 34s.
I just ordered some 295/65r20 (35s) to put on it. If you do the conversion on tiresize DOT com it still will have a stronger axle than a stock 3.73. It’s closer to 3.91 w/ 35s. 35s on a 3.73 knock effect ratio down near 3.55 - NOT a ratio I would want on a truck this heavy and especially not w/ any kind of load.
If you’re putting on a taller (or heavier) tire on, 4.10 is the way to go IMO and after what I have experienced in the first 20,000 miles.
From my experience:
1. I do think the stronger axle helps you in the city without question. I was somewhat surprised at how much heavier these trucks are. Handles noticeably different than a half ton, and that’s without the thousand pounds of extra weight a CTD creates.
The comment was made earlier but it’s a lot more weight to get moving off the line.
2. 4.10 helps you if you get a bigger tire without question - especially regarding #1.
It gives you better performance and is still manageable if you go easy on the highway.
If you are predominantly hwy and stock, a 3.73 will be what 2mpg better? If you’re driving close to 80mph the 3.73 is better. But, if that is the case why the hell are you in a three-quarter tow pig???
What does 2 mpg equate to per year $1K? What is that $5000 over the life of a vehicle? You’ll spend that on the 1500 getting it to look as good as a 2500 and your suspension won’t last nearly as long…
If you’re deadheading all the time, consider getting a 1500 with 3.92 axle on 34s. But even then you have a truck with a nose that looks like a doorstop. ‍
One of the coolest things about a 2500 (for me) is the blunt nose. Yes you pay for it in wind resistance, but it looks like a truck vs. a truck that’s being designed to drive like a car … (1500s)
I can say that although I was originally leaning toward 373 I’m actually glad I ended up with a 4.10 but for reasons I’ve only discovered since having bought it.
I will say that when the transmission is down shifting you can sometimes feel it going down into the low gear. It almost feels like it’s binding up, but it’s simply downshifting - to an extremely low gear. It first concerned me, then it annoyed me, now I just ignore it because it’s not overly frequent or overly noticeable. A 3.73 would prob not do that.
I would vote for a 4.10 unless your empty and hwy 75%+ of the time.
$.02
Moose2
Iowa
I see it this way, if you are asking the question, you probably should get 4:10’s.
cdub5
