3" Lift
COPGUY
New Jersey
Anyone have pics of a Ram with a 3" lift? What is the least expensive lift kit out there that will look good. Not looking for anything crazy.
ramin44s
4.7 v8
you can do a 2.5 level from our vendor HBS for the cheapest and its really good quality stuff and can allow a 35'' tire on alot of trucks. other choice would be 3'' body lift which is gunna be more than the level and you will still have alot of rake, or i think they make a 4'' suspension lift for your truck but it will be over 1000 probably and you could also just do bilstein shocks if your 4wd? that can get you allitle over 2'' up front
COPGUY
COPGUY
New Jersey
Will you notice the lift with the Bilstein 5100's? I am just looking for something to pop it up to the height of a 2500 series, I like the look of the slightly taller trucks. With the Bilstein's, do I just do the front or front and back? Thanks for the help guys.
ramin44s
4.7 v8
Me personally i would just do the front because you have factory rake so it will level the front out with the back or get it close, so if you want to keep the nose down look you can get a block for the rear or use some different shocks that lift, theres alot of options for the rear
quietpeen
2021 TRX
Hellcat
i haven't even looked to know if there is a 3" body lift for the 4th gens, but a 3" body lift and the front leveled would look good with some 35's
Stangshcky12
Oshkosh, WI
5.9 Cummins
A level isnt gonna make it look like a 2500. Unless your truck is 2wd 2.5" is the highest I would go with a level kit
ramin44s
4.7 v8
still think the 5100 shocks would give him the look he wants, a level and 35s or 33s looks really good plus if he decides he wants more lift you didnt waste money on the shocks they can be used for additional lift
durango4819
DE
4.7 V8
you can go the route i went (mods in sig) my truck sits the same height as a 2500, nothing too crazy but a noticeable amount of lift.
Lemniscate_Mike
